Removing Decals- A sticky situation
Old Sep 25, 1999 | 08:07 PM
Mitch Cyr's Avatar
Just thought I'd let you guys know, I tried removing some of the big ugly caution and warning stickers on my 99 Scrambler 400 last night and I was successful! All it took was three things, a hot glue gun, a razor blade, and a chemical/cleaner called "Whip" which can be found at most department stores. I took the hot glue gun and heated a small piece of decal at a time, and then carefully scraped it off with the razor blade. This took a while. After the decal was removed the sticky backing from the decal was still on the fender. I took a paper towel and sprayed whip on it and kept rubbing the spot. Eventually the whip loosened the sticky stuff and the sticky stuff came right off. When I was done I washed and waxed the whole four wheeler and you can't even tell that there was once big ugly warning stickers on the fenders. The spots where the stickers were look nice and clean.
Just thought I'd share this with all of you...
Mitch
99 Scrambler 400
00 Xplorer 400
Old Sep 26, 1999 | 12:29 AM
quad_man's Avatar
That's the first thing I did to my Scrambler, and the Sportsman, when we got them. I was suprised much better they looked afterwards!
I used a blow dryer to heat them, started the edge with a blade, and then just peeled off the sticker by hand. Then I sprayed it with WD40 and wiped it off. Ta-da! Can't even see the outlines.
Old Sep 27, 1999 | 11:17 AM
talon400's Avatar
That is alot of work just use "Goo Gone" 2 secs they come right off. That is the simple way
Old Sep 27, 1999 | 01:17 PM
pflueeb's Avatar
just use gas to wipe off the stickers. That's all
Old Sep 29, 1999 | 09:38 PM
CThorpe's Avatar
Gas will dull the finish on the nice shiny new fenders. I also used a blow dryer to heat and then pealed off. Used diluted Castrol Super Clean Spray to get the sticky stuff off. Still a pain in the a** however, looks good now though. CT 00 Scrambler 500
Old Dec 25, 1999 | 11:38 PM
trailblazer00's Avatar
Why not just us a power washer?
Old Dec 26, 1999 | 02:52 PM
dcop's Avatar
Glad to see others removing those unsightly stickers. After you remove them, the areas around them that have been previously scratched tend to be more noticeable. Has anyone found a good way to polish the plastic to make it look new again? ie..polishing compound and a buffer? I've tried Mothers plastic polish, it adds some luster, however it does not remove scratches?? Thanks, Darryl
Old Dec 26, 1999 | 05:46 PM
eandk99's Avatar
I can tell you what not to buy for polishing your plastic... PC racing's plastic renew..
Its a $20.00 bottle of commercial floor wax...No sh**, thought it was some great new product..... If you want to use wax head for the local hardware store...
Old Dec 27, 1999 | 07:29 PM
evensen's Avatar
The secret to removing those damn decals
is to do it as soon as buy your Quad.
It took me two hours with a hair dryer
and WD 40 to get them off my used 98
Magnum 425. When I get my new Cat-O-Matics
or Magnum 500s in the spring decal removal
wiil happen the day I bring them home.
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
Pgbama11
Jan 16, 2016 08:19 AM
Impalaman
1) Engine problems..
12
Nov 8, 2015 07:17 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
