Polaris Sportsman 90 2001
Old May 16, 2015 | 04:55 PM
Atvman19's Avatar
Default Polaris Sportsman 90 2001
Does anyone know how to fix when I turn to the right the left rear wheel almost completely locks up, so bad that I can't ride. Please help so I can fix the problem.
Old May 16, 2015 | 08:10 PM
Check that the cable isn't in a bind and that you don't have the adjuster too tight on the rear brake drum arm. Dirt Cheap Yamaha, Polaris, Suzuki & Kawasaki OEM Parts & Accessories – Cycle Parts Warehouse
Old May 18, 2015 | 09:51 AM
mitchell424's Avatar
no but i have a q. have ever had a fuel problem for some reason i cant get fuel to then carb carb has been cleaned new battery fuel filter i turn on the gas it doesn't go to the filter its strange but i get fuel coming out of the gas peckcock im baffled. thx
Old May 18, 2015 | 10:08 AM
Open the drain plug on the carb bowl and see if you have fuel draining out. If not,still may be a needle and seat problem in the carb not allowing fuel flow or the fuel line may be routed to where fuel can't flow to the carb.Plus just my opinion,cleaning carbs doesn't always help. Best to install a carb kit Polaris 90 Predator 90 Sportsman carb rebuild kit 03-421 or buy a cheap knock off carb on ebay for $18.http://www.ebay.com/itm/2001-2002-2003-2004-2005-2006-Carburetor-POLARIS-90-SPORTSMAN-ATV-CARB-QUAD-/221035235006?hash=item3376ba06be&vxp=mtr PLUS sometimes hard to get the little ones started that have the electric choke. Block the air box intake tube with your thumb and if the engine is in good shape,should crank right up..Once warm they usually crank ok on their own.
Jmuddin284
Jan 19, 2026 07:16 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
Coryco
Jul 6, 2015 07:30 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
Shifts
Jul 3, 2015 07:59 AM
