Outlaw 450 Cam Timing
Old May 17, 2015 | 08:11 AM
swfl cracker's Avatar
Default Outlaw 450 Cam Timing
I am currently rebuilding the engine on an '07 Outlaw 450 due to a crank pin bearing failure. I am having trouble locating a correct cam timing procedure. Can someone lead me in the right direction?
Old May 17, 2015 | 10:26 AM
Can't remember on the 450 whether it has the crank lock bolt or not. If it does,it's a bolt with a washer at the front lower end of the crank case. Pull the bolt out,remove the washer,turn the engine until the notch in the crank lines up with the hole,install only the bolt to lock it in tdc position.This was mainly for adjusting valves,but can help on cam timing. If this doesn't help here's a reasonable 450 manual. Found the 2008/2009 manual,but the 450 is basically the same. https://www.tradebit.com/filedetail....0-mxr-2008-atv
Old May 17, 2015 | 10:49 AM
Thank you, sir. This is exactly what I was looking for.
Sjrpp
May 2, 2023 03:59 PM
slowgsxr97
Mar 18, 2022 03:40 AM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
95wolv
Jul 17, 2015 08:13 PM
