Tao Tao 110cc starter issue
Hey guys. I've read through all the fourms I can find relating to my starter issue. My issue is slightly different though. First I've had issues before with starting and it ended up being dirt in the foot break relay not allowing the switch to pull in and out enough however the hand break still allowed the quad to be started. The break light doesn't go on at all even with the new foot break switch installed I've tried keeping it loose and also tightening it. Either way I don't think this is the issue. The battery is new and charged. When trying to start the quad the starter makes a humming/whinning sound not a typical click a starter usually makes when there's a problem. I tried touching the two bolts together on the starter with a screwdriver... there IS a small spark but starter won't turn, it does however make a very quiet but fast typewriter type sound when bolts on starter are being touched but definitely not a click or a turning over sound. im not sure if im just hung up on the sound its making but i dont know if the starter is actually bad considering it does make a noise..just not a common noise. thanks for your time reading all this
and for any advice
mike
and for any advicemike
and for any advice
mike
