Yamaha Big Bear 400
Old Jun 8, 2015 | 08:28 PM
Yamaha_'s Avatar
Default Yamaha Big Bear 400
I have a Yamaha Big Bear 400, and let me just say that I love yamaha and hope to get this resolved. 1st problem is it won't idle, carbs have been cleaned, and I have a fuel filter on it. The problem is the choke cable. If I move the handlebars one way, it'll just cut off because the choke cable moves. I will turn it on, and it will immediately shut off because it is moving.?? 2nd problem is, it's smoking when I start it up, but when I put it in gear and start to ride around it will stop rather quickly. I use 20w 50 Yamalube, but think maybe it's low right now. Hoping that putting the right amount in will stop the smoking. Hopefully it is not valve seals.
Thanks.
Old Dec 16, 2022 | 07:49 PM
Muddygirl1009's Avatar
Default Need help
I have a big bear 400 ran well never had issue then one day was riding turned it off went to start it back up and CDI BOX started smoking. I then replaced it, stator, coil, handle start, and solenoid, charging box ...now it still won't start and no fire to my plug... PLEASE HELP. Don't wanna keep buying parts if I s something else or simple fix without buying a part like wire or something.
please help thanks
Michaellaurent
Dec 16, 2022 07:41 PM
batdist
Jun 20, 2022 01:28 AM
YAMAHA400BigBear-Jianshe
Sep 10, 2011 11:28 PM
sandrunners
Utility ATVs
Nov 22, 2009 11:41 AM
krazy3t
Oct 8, 2003 11:00 AM
