Lt185 Reverse Grinds but dosent engage
Hi,
I'm in the process of rescuing an old 1985 LT185 and I've got an issue with reverse, When I engage it the gear grinds but there is no drive, if I jack the wheels of the ground then then the wheels turn backwards but as soon as I introduce resistance they will stop and the grinding noise comes back. Sounds like the gears are not engaging fully, Is there some kind of adjustment or is this a worn gear and I'm going to have to go into the crankcase?
Any help would be appreciated,
Thanks
Thanks
I had an '84 185 and it always made a grinding sound when going into reverse unless I shifted in and out of 1st gear. Check to see if you can adjust anything to make sure the pull up handle is going into the fully engaged position.
