Leaking battery
Old Jun 29, 2015 | 06:20 PM
traumajunkie's Avatar
Dr in a box
Default Leaking battery
Found my brand new battery leaking all over,
1) Why is it leaking?
2) Did the acid hurt my 4 wheeler?
Old Jun 29, 2015 | 09:09 PM
scootergptx's Avatar
Supersock
Hired Gun!
Could be cracked, would be the first thing I'd look at. Did you get to ride with it or did it leak right after you installed it?
Yes, depending on what all that acid gets on, it can be very bad.
Old Jun 30, 2015 | 04:16 AM
Either you turned it on it's side, the case is cracked, someone overfilled it with acid, or you have boiled it. If it is neither of the first two, check if the voltage regulator has packed in by putting a voltmeter across the battery with the engine running, If you get over 15v with the engine revving, you need a new regulator. Acid corrodes metal parts such as steel and copper.
Old Sep 7, 2015 | 08:39 PM
DM2015's Avatar
Default JB weld
If u loose acid it can be refilled from a battery shop and if the case is cracked jb weld it just let it dry 24 hours it worked for me don't go buy a new one
slowgsxr97
Mar 18, 2022 03:40 AM
Cummins Driver
Sep 11, 2019 01:22 PM
willday08111217@gmail.com
Technical and How-To Articles
Aug 1, 2015 04:05 AM
Hankey Pankey
Jul 31, 2015 05:50 PM
Unzzy66
Jul 11, 2015 10:01 PM
