Aauugh! Yamama oil filters interchangeable?
Old Jul 6, 2015 | 08:10 AM
lightninboy's Avatar
Default Aauugh! Yamama oil filters interchangeable?
I bought an oil filter at my dealership for a 2005 Kodiak 450 and the partsman gave me 5GH-13440-50-00. But there are also 00-00, 20-00 and 30-00 versions mentioned on the Internet. Some might be 1/4" shorter than the others. Some might be built by a different manufacturer or built in a different country. Some might be for marine applications and some might be for cycle applications. They might all be equally interchangeable and they might not. So, what is the deal? It's about confusing enough to want to just go to O'Reilly Auto Parts and buy a Wix and some Valvoline.
Old Jul 6, 2015 | 09:20 AM
scootergptx's Avatar
Supersock
Hired Gun!
From what I've seen on the motorcycle forums, they are supposed to be interchangeable. One person said those indicated the year it was made, but I have no proof of that. The change in size isn't uncommon as they use these in several machines so space may have become an issue on a newer model.
Also found this conversion list.
Old Jul 6, 2015 | 10:13 AM
TLC's Avatar
TLC
I just changed the oil on my Polaris 500 and 350 Grizzly and friends 660 Grizzly.
Found out they all take the same oil filter. So if you want another option these filters will work. The longer 3.5" vs the 2.5" long are a tight fit on the Yamaha but do fit.
These Oil Filters have 20 x 1.5mm threads, 14 psi by-pass valve, anti-drain back valve, 2.3" O.D. gasket 2.5" to 3.5" long.
I,m using the Fram PH7317 in both my Yamaha and Polaris currently.
Motorcycle Filters.
AC Delco PF2135
AMSOil SMF103
Carquest 85358
FRAM PH6017A
Honda 15410-MCJ-000
K&N KN-204, about $13. Metric nut on end for easy removal.
NAPA Gold 1358
Purolator ML16817. Imported, not made by Purolator.
STP SMO 17
WIX 51358
WIX PS1358
Recommended filters. All have superior filtering. (I,m told)
About 2.5 inches long.
Purolator Pure One PL14612, about $6.
Mobil M1-108, about $12. Made by Champion.
Bosch 3300, about $6. Made by Champion.
About 3.25 inches long.
Purolator Pure One PL14610, about $6.
Mobil 1 M1-110, about $10. Made by Champion.
Bosch 3323, about $6. Made By Champion.
WalMart SuperTech ST7317,about $2. Made by Champion.
Buy these filters Automobile Filters,about 2.5 inches long.
AC Delco PF1237
Baldwin B1400
Firestone TF2876
Hastings LF113
NAPA Gold 1365
Purolator L14612
STP S-02876
WalMart SuperTech ST6607
WIX 51365
Automobile Filters, about 3.25 inches long.
AC Delco PF-2057
Auto Pro 2356
Autopride CF240AP
Baldwin B1402
Carquest 85356
Carquest Red B4620
Casite CF240
Castrol 7317
Champion Labs Ph2867
Defense Filters Dl7317
Deutsch D-370
Federated Filters LF240F
Fram PH6607
Fram Double Guard DG7317
Fram PH7317
Fram Tough Guard TG7317
Fram Xtra Guard XG7317
Group 7 V4610
Group 7 V4620
Hastings LF240
Mighty M4612
Motorcraft Long Life FL-821
Napa FIL1356
Napa Gold 1356
Parts Plus PH2867
Pennzoil PZ-109
Penske 7317
Powerflo SL14610
Powerflo SL14620
Pro Gauge PGO-4620
Pro Tec 164
Promotive PH4610
Pronto PO3593A
Purolator L14610
Service Champ OF-4622
Shell SH48
Shell SH529
Stp S-02867.
Valvoline VO50
Warner PH2867
Wix 51356
Wix PS1358 (specific for ATV's) What ever that means.
Old Jul 6, 2015 | 10:46 AM
I called the dealership and the partsman said the original filter was 5GH-13440-00-00 and then superceded to 5GH-13440-30-00 and now superceded to 5GH-13440-50-00. He says he does not really have much Yamaha experience but that is official from Yamaha.
Old Jul 6, 2015 | 10:55 AM
TLC's Avatar
TLC
I pride myself on not walking into dealerships traps often. Go to a Wal-mart and get a
WalMart SuperTech ST6607 and be done with it.
Old Apr 22, 2021 | 10:44 PM
Well, it's oil change time again. The Yamaha ATV oil filter is now 5GH-13440-61 which supercedes 60 and 50. There are 70s and 71s but they may be mainly for outboards. The Yamaha partsman stocks only expensive Yamalube 10W-50 synthetic blend for Yamahas and AMZOIL synthetic for all makes. He doesn't recommend Valvoline 10W-40 mineral ATV oil but admits he never heard of any damage done by it. Now, here's the killer. He doesn't stock Yamalube Foam Air Filter Oil. He sells K&N Air Filter Oil Spray for universal air filter oil. It seems to me it's basic knowledge you're not supposed to use K&N oil on foam air filters.
Old Apr 23, 2021 | 07:01 AM
Supersock
Hired Gun!
You can use motor oil on a foam filter. We used to use 2 stroke oil on ours, back when we had 2 strokes.
Old Apr 23, 2021 | 09:37 AM
I know motor oil/chainsaw bar oil is okay to use on a foam air filter if you reoil it often enough. I like Yamalube foam air filter oil because it is tacky and it does its job until my next oil change. But K&N is a different animal.
Old Apr 23, 2021 | 11:13 PM
I scrutinized online the different foam air filters and their oils and cleaners. I'm thinking, to stay rather O.E.M. use genuine Yamaha air filter, Yamalube 1-pint synthetic foam air filter oil, Caltric air filter, Maxima FFT 1-pint semi-synthetic foam air filter oil, Maxima foam air filter cleaner or your own domestic solvent, to go rather aftermarket use the Uni filter, oil and cleaner.
Old Apr 24, 2021 | 01:52 AM
On a single cylinder four stroke ATV engine, the piston is pushing whatever CCs the engine is, of oil fume laden crankcase air into the airbox at every downstroke, if that doesn't keep your air filter oily, nothing will.
