blaster
Old Aug 17, 2015 | 04:56 AM
scott1988's Avatar
Default blaster
I have a 2006 yahama blaster 200 starts up good and was running good now it bogs down i have cleaned the carb and plug i think the gas is too rich (to much oil) could that cause it bog down
Old Aug 17, 2015 | 07:31 AM
Scooter86's Avatar
Knows Old ATV Questions!
To much oil actually will make it run lean (less gas available) In my experience, if the plug was fouled, you are better off replacing it. Anything change since it was running good? Have you tried fresh gas?
Old Aug 17, 2015 | 07:35 AM
scott1988's Avatar
No nothing has been replaced thats my last option is to drain that gas and go with fresh gas
Old Aug 17, 2015 | 08:43 AM
Dazeys's Avatar
Can't wait to feel that 130 HP at the dunes.
Yes, change that plug. Too much oil could plug the exhaust. Make sure it is clear.
Old Aug 17, 2015 | 08:48 AM
scott1988's Avatar
Dazeys.....how excatly can i make sure the exhaust isn't clogged up lol im not a mechanic by a very long shot lol......and i noticed since i put this gas in its started smoking like its to to rich should i change the gas to??????
Old Aug 17, 2015 | 03:04 PM
Scooter86's Avatar
I would go buy and mix up a fresh gallon. Not sure on the stocker, but an aftermarket exhaust usually absorbs unburnt oil over time and can effect performance. Worth repacking if you havn't done it in a while and it is aftermarket. Actually, are you still running the oil injection?
Old Aug 17, 2015 | 03:12 PM
scott1988's Avatar
Scooter86...... I have a bills performance aftermarket pipe on it i just bought the bike froma buddy of mine so idk when the last time it was packed or whatever but how do you do that lol
Old Aug 17, 2015 | 03:57 PM
Scooter86's Avatar
It is just the silencer that needs repacking. Some companies are good to you and have bolts that remove, usually at the rear opening. Sometimes it is riveted though. Then you slide the internals out, wrap some new packing material and slide it back in. Tighten the bolts or rivet it back up. If you have any questions, I would call the manufacturer. Should be some decent vids up online too.
Old Aug 17, 2015 | 04:04 PM
scott1988's Avatar
Ok thanks
Old Aug 18, 2015 | 08:44 AM
Dazeys's Avatar
Good thought on the oil injection. Is yours still there and your mixing oil also? I removed mine as soon as I got the blaster.
Ahtatu
Sep 28, 2015 12:14 PM
nastyblaster100
Sep 13, 2015 01:19 PM
1966F100
Aug 21, 2015 07:10 PM
315blaster
Aug 8, 2015 08:13 PM
drewy2dope
Ask the Editor
11
Jul 31, 2015 09:36 AM
