Wiring Issue
Old Aug 18, 2015 | 01:07 PM
frostphase's Avatar
Default Wiring Issue
So I acquired a Chinese 150cc ATV. Someone had just absolutely butchered the wiring harness, I think in an attempt to bypass the kill switches.
I bought a new harness on eBay, installed it yesterday but there's just a couple things I'm unsure of.
1. The green ground wire that I'm assuming connects to the battery, where does the other end connect at? The solenoid?
2. There's a plug coming from the shifter that someone snipped a white/black wire on it.
3. If I connect the green ground wire to the battery and to the solenoid and connect that plug coming from the shifter into a plug on the harness.. the bike will start cranking o.O
Any help is greatly appreciated!
Old Aug 19, 2015 | 02:21 AM
Thick ground wires connect to the battery and ground. A thin earth wire will go to the small connector on the solenoid if the other thin wire to the solenoid is live only when you press the start button. Wires from the shifter are for either a safety lockout which prevents starting in gear, or a display of what gear it is in on the dash, maybe both.
Old Aug 19, 2015 | 07:11 PM
frostphase's Avatar
thanks a lot for the help! Issue is solved, running fine now.
Unzzy66
Jul 11, 2015 10:01 PM
sublime250
1) Engine problems..
Jul 11, 2015 11:52 AM
Chocobamofo
Jul 10, 2015 07:46 PM
Albertascramblerx
Jul 8, 2015 11:56 PM
D-Hagz
Jul 4, 2015 02:19 AM
