Is it bad to use a winch as a tie down?
Old Oct 18, 2015 | 02:53 PM
TLC's Avatar
TLC
Default Is it bad to use a winch as a tie down?
I was told it was bad to use a winch as a tie down when on a trailer. I had a Warn that died on my sportsman maybe because of using it as a tie down?
I don't want the same thing to happen with my 350's winch.
Old Oct 18, 2015 | 06:45 PM
user493's Avatar
Moto Psycho
Yes. It's not safe or smart. Many owner's manuals specifically say not to do it.
Old Oct 19, 2015 | 01:58 AM
greg74's Avatar
I think I ruined a winch potentially prematurely by doing that. I had another Grizzly 660 several years ago with a Viper 3000 lb winch with synthetic rope. We didn't trailer it that much, mostly rode nearby. The gears stripped out and it quit working within about a year. I think perhaps it was because the winch was probably of inferior quality more than using it as a tie down point but I'm sure it didn't help. It is convenient to use the winch but it is very hard on the gears inside because of the shock they receive from bouncing around on the trailer going down the road.
Old Oct 19, 2015 | 08:58 AM
RedRocket204's Avatar
You may also want to check your local DOT regulations as well... be that USA or Canada. I've read where a lot of DOTs require 4-point, independent tie downs. That would indicate a winch would only be a single tie down and possibly violating some DOT regulations.
Best to verify your local DOT regs.
Old Oct 19, 2015 | 02:41 PM
user493's Avatar
Moto Psycho
Winches are made to have a constant pull not jerking on the cable that comes from bouncing. If that was the only thing holding the ATV down and the gears stripped it would be goodbye quad. I always use 4 tie-downs, one to each corner of my trailer.
Old Oct 20, 2015 | 12:38 AM
greg74's Avatar
There was a tie down on the back of the quad but yes it was the only thing holding it from the front. I will most likely never do that again.
mopar4u
Dec 1, 2015 09:43 AM
panikrev
Oct 13, 2015 09:27 AM
countryboy26047
Oct 12, 2015 03:14 AM
bbradford
Oct 10, 2015 09:52 PM
exmotocrosser
Sep 26, 2015 08:18 AM
