'05 arctic cat 650 v2 ticking noise
Old Oct 21, 2015 | 02:24 PM
elishaman79's Avatar
Default '05 arctic cat 650 v2 ticking noise
My atv was running fine yesterday and was quiet, no noise. This morning I started it and it is ticking as if all the valves need adjusting. I pulled covers off front cylinder just to check and all the valves are fine. Any ideas appreciated. OK since I posted this I have pulled both clutches off and changed oil and filter. Used paint strainer to run draining oil through in case and foreign particles. Everything looks fine. Left clutches off and put new oil and filter in and noise still there.
Old Oct 22, 2015 | 09:12 AM
Zrock's Avatar
Super Quad Patrol
Have you taken compressed air and cleaned out your clutches? Belt dust and dirt will start to make things chatter. Also look for exhaust leaks
Old Oct 22, 2015 | 09:27 AM
Both clutches are still off. Since I posted this I have removed both timing chain tensioners. The left one is completely extended and right one about 1/3 of way extended. Looks like timing chains are the problem. Would you remove motor from chassis and do it on bench or is it easy enough to do in chassis?
Old Oct 23, 2015 | 09:26 AM
Zrock's Avatar
Super Quad Patrol
if ya can do it in why go to the extra work of removing
Old Oct 25, 2015 | 02:50 PM
FYI you can not do it in the frame. It is impossible to remove the rear cam cover. Motor must come out.
littleboots
May 6, 2020 10:22 AM
ed palmer
Oct 18, 2015 03:03 PM
Mac25
Oct 17, 2015 10:14 AM
bloodknuckles
Oct 5, 2015 10:01 PM
maveikfe
1) Engine problems..
Sep 24, 2015 10:36 PM
