shift lever by pass
Old Nov 2, 2015 | 10:21 PM
trapstar56's Avatar
Default shift lever by pass
I have a 1996 polaris 400 explore awd, some time ago I started having trouble with the awd engaging. a bungy cord worked holding shift lever as far forward as possible. I saw on u tube where a chap by passed the switch on the shifter by moving a wire, gr/white I believe to a red/wh post and he had awd without replacing or doing anything to the switch that is engaged by the shift lever. quick and cheap can I do this on mine?
thanks keith
Old Nov 3, 2015 | 12:16 AM
Moving the shifter switch gray/white wire lead to the red/white terminal on the circuit board should power up the solid gray wire in the switch. From the shift switch the gray wire goes to the awd button. I believe this should work.
Old Nov 3, 2015 | 08:55 AM
TLC's Avatar
TLC
Different from mine , the shift lever only choses forward, reverse ,low and neutral and nothing to do with with AWD.
Old Nov 3, 2015 | 09:07 AM
Polaris finally got smart on 99 models and up and installed the gear position switches on the transmission where they should have been in the first place. Items 12,13.Dirt Cheap Yamaha, Polaris, Suzuki & Kawasaki OEM Parts & Accessories – Cycle Parts Warehouse
Apr 23, 2017 07:42 PM
nick c
Sep 13, 2015 10:08 AM
chewy78
Sep 8, 2015 10:37 AM
slowgsxr97
Sep 8, 2015 04:37 AM
colt1126
Aug 18, 2015 08:27 PM
