Polaris Magnum 330 Won't go in to High Gear or Park
Old Nov 6, 2015 | 05:33 AM
Gunzo's Avatar
Default Polaris Magnum 330 Won't go in to High Gear or Park
I have a 2003 Magnum 330 Automatic Transmission. Just recently it stopped going in to High Gear or Park. Although it will go in to Reverse, Neutral and Low gear ?
Please advise where I should begin troublehooting.
Thanks
Gunzo
Old Nov 6, 2015 | 07:10 AM
Make sure the spring on the brake pedal that operated the park interlock hasn't stretched or come off the interlock. Item #28.Dirt Cheap Yamaha, Polaris, Suzuki & Kawasaki OEM Parts & Accessories – Cycle Parts Warehouse If the interlock and spring are ok,the problem most likely is behind the gear selector cover on the transmission. Water,moisture can get into this area and corrode the shift gears up or possible you could have broken tooth on one of the small gears.Here's one persons post on Polaris ATV Forum and problems on a 700 that shares a similar type transmission and what he did. Hard to Shift 700 Sportsman 2004 - Polaris ATV Forum
Old Nov 8, 2015 | 08:27 AM
Gunzo's Avatar
Default Gear shift issues polaris atv
Thanks for the feed back.
Yes the Spring came off of ther brake pedal.
Easy fix, for once !!
Keepn the Faith
Old Nov 8, 2015 | 09:37 AM
Glad it was simple. I hated those springs as they stretched over time and you either had to push harder on the pedal to engage gears or they would come loose..
Roll_on_Stone
Nov 4, 2015 05:08 AM
Jared Nichols
Nov 3, 2015 08:29 AM
stepadery
Oct 19, 2015 05:51 PM
Jhwaco
Oct 19, 2015 05:25 PM
