2003 Sportsman 500ho sputtering
Old Nov 2, 2015 | 06:36 PM
Jared Nichols's Avatar
Default 2003 Sportsman 500ho sputtering
Hello I recently bought a neglected 500ho sportsman. I rode the quad a few hours then battery died. I replaced battery and quad started running rough. I went through carburetor, looked ok except pilot jet was plugged. Quad ran ok for awhile then started overheating. I checked all the bag relays for power and cleaned a bunch of electrical connections. I found the fan was seized up so I replaced that. I haven't run the quad much because now it's sputtering. Sometimes if I hook up the wire that bypasses kill switch it will die. So I am trying to diagnose the sputtering as electrical or carb. I think maybe electrical cause when I plug the wire in sometimes the quad shuts right off. I also have no speedometer or lights on my dash pod. I messed around with air fuel screw when I did carb but thought I put it back where it was. Is this screw accessible with carb on engine?
Old Nov 3, 2015 | 12:32 AM
If you have a small screw driver or a carb tool you can adjust the idle mixture screw.Motion Pro Motorcycle Carburetor Pilot Screw Adjusting Tool Carb Mixture 08 0119 | eBay Sounds like you need a manual in the worst way.Here's one for 5 bucks that can save you some grief.2003 Polaris Sportsman 500 Service Manual PDF Download
Old Nov 3, 2015 | 05:16 AM
Thanks for the link for the manual. That will be a big help. I'm gonna try to reach in with a screwdriver and adjust carb. Also checking the hot light switch in head to see if that's functioning. Trying to diagnose whats up with the dead speedo. Seems like a common issue with these quads.
Old Nov 3, 2015 | 08:29 AM
Here's a couple different posts on speedo repair. One from member TaterTots.AWD and Speedometer don't work - Page 2 - ATVConnection.com ATV Enthusiast Community https://www.google.com/url?sa=t&rct=...DUHOp6eZQ6EgBw
freeman34
Jan 8, 2016 11:46 AM
hueby
1) Engine problems..
Aug 29, 2015 08:34 AM
hueby
Aug 28, 2015 07:26 PM
frostphase
Aug 19, 2015 07:11 PM
sportsman2005
Technical and How-To Articles
Aug 19, 2015 10:52 AM
