Carb Problems
Old Nov 12, 2015 | 05:18 PM
Clea1963's Avatar
Default Carb Problems
New to the forum and Need Help, I rebuilt carb on Kodiak 400 and it bogs down when you start to give full throttle. Can someone help with what I did wrong.
Old Nov 13, 2015 | 01:41 AM
If you installed a rebuild kit were the jets the same size as the originals? Float level set correctly? Plus if it's a cv carb are you sure you have the slide needle clip properly in place along with with the diaphragm spring? If you don't have the air box installed yet that can cause one to lean bog also. See if this video might help you retrace your steps.
Joesn68
30
Jul 7, 2024 09:32 AM
Johnnye23
Nov 16, 2015 06:35 AM
mmumm
Nov 8, 2015 12:27 PM
bigpollyboy
Nov 6, 2015 06:20 PM
brapbrapguy
Nov 6, 2015 04:06 PM
