Need help with Parts Interchange
Old Nov 26, 2015 | 09:38 AM
Dracoheart's Avatar
Default Need help with Parts Interchange
I just received a Mid to Late 80s Moto-4 350 from my father-in-law for free so i am trying to bring this quad back to life so i can use it for the ranch and some trail riding. The motor turns over so now it is a matter of replacing most of the original parts.
I know they still sell things like the clutch discs and brakes, but what parts can i use for things like the shocks and carb? What other quad parts work with this machine? I know i need a new carb because this one has some broken parts and the shocks are shot. I also might need the centrifugal clutch assembly and other maintenance parts.
Any advice on where to start?
Old Nov 27, 2015 | 08:57 PM
Dracoheart's Avatar
I know some stuff will mix from the Kodiak and Warrior but i am not 100% what does and does not.
Old Nov 28, 2015 | 02:55 AM
The 350 Big Bear and Moto 4 were almost identical, apart from 4WD, in fact a lot of Big Bears have Moto 4 cast into the mudguard plastics, so they must have shared plastics. Check the on-line parts books for shocks and carbs with the same part numbers, are you sure Yam dealers don't still stock them?
Old Nov 28, 2015 | 03:12 AM
Dracoheart's Avatar
I will try and find them that way then cause the yamaha website shows me the part number but when I click it the window pops up with "Not Available" in red for both the front and rear shocks. The carb I have seen on ebay but some stuff is still really hard to find even used.
Update: my original shocks are 3hp-23350-00-33 while the shocks off an 89 big Bear are 3hn-23350-00-33. I think the shocks are the same but the Big Bear has a larger spring in the front I am guessing for the 4wd but I think it might work.
Old Dec 6, 2015 | 04:04 PM
Dracoheart's Avatar
Ok i was way off on the year of the quad. Stopped by buddies shop to grab the vin off the quad and it came back as a 1995 Moto 4 YFM350ERG. Anyone know if the stuff off the 1995 Kodiak, wolverine, or warrior will be the same?
GregM
10
Oct 5, 2015 12:14 PM
cornermike
Oct 3, 2015 12:49 PM
oliveiracarlos
Sep 7, 2015 03:39 AM
oliveiracarlos
Sep 6, 2015 01:38 PM
