Chain / Sprockets??? - Polaris 97 Xplorer 400
Old Jan 11, 2016 | 08:12 AM
KG_97xplorer's Avatar
Default Chain / Sprockets??? - Polaris 97 Xplorer 400
I need to replace my two rear sprockets and chain on my Xplorer 400 4x4.
OEM is pretty expensive and not sure it is the better option... Wondering if I should go aftermarket ? I've found Primary Drive replacement or Sunstar replacement sprockets. Any experience with either of these brands? Not sure which chain I should be considering. I know it is a 520 with 84 links.
Any advice would be greatly appreciated!!!
Old Jan 11, 2016 | 08:24 AM
Sunstar or JT sprockets are a couple of good aftermarkets I've used with no problems on atvs. Even had a JT front sprocket on my old Honda street bike. Good alternatives to oem plus they offer different sizes not available from manufacturers. Make sure the chain is a good quality o-ring. DID,Regina,Tsubaki,EK,Renthal to name a few.
Old Jan 11, 2016 | 08:58 AM
I'll order the Sunstar. I see O-ring and X-ring. I need the O-ring? Any significant differences in chain qualities? Is there something specific I should be looking for? I see a moose that sounds good for $79?
Mooses new high-quality O-ring chain features extra-high-tensile strength link plates and side plates with rust-resistant nickel-plating
Grease is vacuum-injected into wear areas
If your motorcycle came from the factory with O-ring or newer style sealed chain, it must be replaced with a sealed chain. Heavy-duty chain is not for use on a motorcycle that came stocked with a sealed chain. Also, standard chain is not suitable for racing or any motorcycle which came stock with a sealed or heavy-duty chain.
MAXIMUM ENGINE SIZE: 750
TENSILE STRENGTH (lbs): 7480
Old Jan 11, 2016 | 12:44 PM
Moose is a good chain also from what I've heard. Probably made by one of the major manufacturers for them. My choice would be either a DID or Regina as we sold quite of few of them over the years. DID is more than likely what is on your atv now if you check.
Ipmcelroy
11
Jan 12, 2016 12:03 PM
Michael Wood
2) Chassis problems..
Jan 5, 2016 01:45 PM
Ipmcelroy
Dec 28, 2015 10:23 AM
Ryansgt
Dec 15, 2015 10:31 AM
