2014 arctic cat 700 trv error code P0261
Old Jan 19, 2016 | 06:34 PM
J.Kean88's Avatar
Default 2014 arctic cat 700 trv error code P0261
I was recently out for a ride on my atv and it all of a sudden died on me while I was waiting to cross a road. Error code P2061 which is L4 rear cylinder injector circuit low but I can't seem to find any info on fixing this? My warranty is currently up and wondering if it's something I can hopefully fix it my self, any help would be gratefully appreciated.
Old Jan 20, 2016 | 08:32 AM
Zrock's Avatar
Super Quad Patrol
First thing i would do is go through all your connectors clean them up and put some dialectric grease in them. dirty connectors will give to bad readings. Had similar have not had a issue again since i greased the connections
Old Jan 20, 2016 | 08:45 AM
J.Kean88's Avatar
What do you use to clean up the connectors? Electrical cleaner? And when you use that grease do you just put it around the connectors where they slides together or inside where the connectors make contact?
Old Jan 20, 2016 | 09:43 AM
Alex G.'s Avatar
Any of the auto part stores will carry some brand of electrical connector cleaner. WD40, CRC whatever. Spray them good and use a old toothbrush to get out anything built up, then spray again and let dry... put on a decent dab of dielectric grease and re-assemble...
Kainedogg
Jan 22, 2016 04:35 AM
ATVAdventurer
Where to Ride
Jan 10, 2016 02:00 PM
Michael Wood
2) Chassis problems..
Jan 5, 2016 01:45 PM
evanmc1994
Where to Ride
Dec 28, 2015 12:42 PM
Ipmcelroy
Dec 28, 2015 10:23 AM
