350 Wolverine shifting
Old Feb 1, 2016 | 08:07 AM
NCLandBroker's Avatar
Default 350 Wolverine shifting
I have a 2000 Wolverine 350.
I just got finished cleaning the carb and doing some other minor stuff on it. Took it up the street to verify carb function and when I upshift, the shifter needs to be pulled upward to shift, then tapped back downward slightly so it "falls" into the next gear. If not tapped into gear, machine fails to go into gear. Downshifting is as normal, no problems there. It just suddenly started doing this today.
Any thoughts on what this might be? Do I need to adjust the shifter or something?
Old Feb 1, 2016 | 08:31 AM
Not familiar with the cover the shift shaft goes through but may be a seal or plain case bearing causing it to stick or could be a shift stopper spring may have broken or shift shaft spring problem. Had a couple spring problems like this on our Polaris Expeditions and few old Hondas that came through the shop that the lever wouldn't return. Item#12 or 14.Dirt Cheap Yamaha, Polaris, Suzuki & Kawasaki OEM Parts & Accessories – Cycle Parts Warehouse Others more familiar with the Wolverine can probably direct you right to what happens most often.
MapleNeil
May 30, 2016 11:16 AM
Whitelx1
Jan 15, 2016 11:52 AM
Ipmcelroy
11
Jan 12, 2016 12:03 PM
Louie M Locc
Technical and How-To Articles
Jan 4, 2016 12:47 PM
NCLandBroker
Dec 5, 2015 03:21 AM
