1993 Timberwolf engine rebuild
Old Feb 5, 2016 | 08:36 AM
sefh3's Avatar
Default 1993 Timberwolf engine rebuild
I'm needing help. I have the engine all tore down. I noticed this seal was laying on the bench. Were does this go?
Old Feb 5, 2016 | 08:54 AM
Fasteratv's Avatar
Can't help you....your manual doesn't provide any info on that particular part?
Old Feb 5, 2016 | 09:27 AM
Looks like a clutch lever case seal or shift shaft seal??
Old Feb 6, 2016 | 07:38 AM
sefh3's Avatar
The clutch cover seal is still there. I'm thinking it came from inside the motor from somewhere.
Old Feb 6, 2016 | 08:01 AM
sefh3's Avatar
I looked thru the manual and can't find it listed.
Old Feb 6, 2016 | 08:31 AM
You'll either find it when you start to put it back together or it could be like some aftermarket kits I've seen that have extra parts that may be used on an earlier or later models.
Old Feb 6, 2016 | 08:35 AM
sefh3's Avatar
The problem is I didn't buy a kit. It came off the motor from somewhere as it's still on the bench. Just need to know where it goes. The picture was for reference.
Old Feb 6, 2016 | 08:49 AM
OOPS.. Then you better look real close.
Old Feb 6, 2016 | 10:42 AM
I've only rebuilt 350 Yam engines but it looks like the oil gallery seal, can't remember if it goes between head and cylinder or cylinder and block, but fits round one of the studs.
Old Feb 8, 2016 | 06:26 PM
Timbo2500's Avatar
Like Merryman said, it looks like the seal on # 9 of the attached cylinder head picture. Also look at the other picture with my finger pointing at the location where it goes on my Big Bear 250...
P.j,
Feb 9, 2016 07:52 AM
sefh3
Technical and How-To Articles
Feb 4, 2016 07:59 AM
dstressman
Feb 3, 2016 03:11 AM
Timbo2500
Jan 14, 2016 02:40 AM
goatfarmer
Jan 13, 2016 09:22 AM
