2005 650 v-twin
There should be one fuel inlet per carb...each carb has it's own. The only "overflow" that I know of on the carbs is the nipple protruding from the carb bowls....one on each bowl and should have a very small hose connected to each. This is the Kawie 650 twin...right?
Had Arctic Cat on the brain,sorry.. Principle is still the same on most twin carbs. Have to have an atmospheric vent,usually at the top or middle of the carbs separated by a tee into a single tube. Same for the fuel supply.
there seems to be one gas line in to the carbs. Now were does the tee on the left side of the carbs runn to , would this run down to the bottom of the waterpump or is this a overflow running back to the gas tank. My manuels does not give this info
amalota
Feb 5, 2016 01:45 PM
JOE3824
Feb 1, 2016 02:52 PM
