two stroke oil ?
Old Mar 3, 2016 | 11:57 AM
grapejuice420's Avatar
Default two stroke oil ?
Can't seem to find an actual answer so I'll ask here. What type of oil is everyone using in there oil injection systems ? The quad is a mz 100cc if that matters thanks
Old Mar 4, 2016 | 07:11 AM
TLC's Avatar
TLC
Any 2 stroke injection oil will work. Do you have a Walmart near you? Just in case read the label to see if its for injection systems.
Old Mar 4, 2016 | 07:22 AM
Yes not to far from my house thanks for ur reply
Old Mar 4, 2016 | 07:37 AM
TLC's Avatar
TLC
If the stuff is for "Pre Mix only" use any snowmobile oil, they are all for injection systems now. Castrol is a good one.
Old Mar 4, 2016 | 07:44 AM
LT80's Avatar
LT80 Expert
I like synthetic 2 stroke oils.
Old Mar 4, 2016 | 07:46 AM
MPDano's Avatar
I use Maxima products. Any motorcycle shop or even ebay will have them. 2 stroke or 2 cycle.
Old Mar 4, 2016 | 08:26 AM
Thanks for all the replys I've never owned one with injection before only mix so wasn't sure what I need thanks again
Old Mar 4, 2016 | 08:39 AM
MPDano's Avatar
No worries. Basically the same as pre-mix oil. Honestly, I don't trust oil injection. I've blocked off the injection and pre-mixed my own gas. It's safer.
Old Mar 5, 2016 | 07:42 AM
TLC's Avatar
TLC
I heard you do not use pre mix in a injection system. Not sure if it matters but why rick it.
100cc your fine . Snynthic is for high performance and pricy. I use it in my ski-doo 800R E-Tec but it's 165hp stock.
Old Mar 5, 2016 | 08:21 AM
MPDano's Avatar
Yes you heard right. This is why I said "block" off the oil injection. Oil Injection systems are known to fail and send 100% straight gas to your 2 stroke motor. This will grenade it in a heartbeat.
