two stroke oil ?
Use 32:1. I use a measuring cup which will tell you how much oil to a gallon of gas.
Thanks I pulled the tank out and just plugged the line drained all the gas out and mixed up a 32:1 mix per ur guys suggestions I ordered a new carb today for it I've taken the old one apart and cleaned it a few times now and it doesn't wanna stay running tried to adjust it per another post on this forum but still some thing wrong so hopefully the new one will be good
#15
#17
yeah, they get worn out with age. I would just clean them real good. make sure you can see light thru them. the idle jet will be hard but you can still see light. keep them just in case you need to swap out one or the other.
Robert.unger
1) Engine problems..
Mar 4, 2018 02:33 AM
Whitelx1
Feb 29, 2016 12:54 PM
