What size paddles?
Old Apr 11, 2001 | 10:57 PM
Xplor's Avatar
I am heading out to Silver Lake on May 12th and want to buy some paddles for the Scrambler. I am wanting new rims also, so I am trying to decide between 20" and 22" rears? Any suggestions? Stock size is 22" rear and 23" fronts. The reason I ask is because I intended on getting smaller front(21") and rear(20") Razrs for after the dune ride so I could re-use the new aluminum rims for mounting smaller, sportier trail tires.
Old Apr 13, 2001 | 07:13 AM
skull's Avatar
go with the 22".
I had a chance to ride both on my 300ex and there was no comparason. the 22" tires are way better. the taller tire seems to float better instead of dig, and I could run less air to get a smoother ride. if you go with the 20" you'll lose a lot of top end, which you'll really need in the dunes.
good thing I only borrowed the 20".
Old Apr 17, 2001 | 06:31 AM
ZEBRATRAILER's Avatar
This may be kinda late, but if you stay with stock diameter tires you can run 4x4. I switch from 2 to 4, depending on conditions. Hill climbing is alot of fun in four wheel drive. a guy that goes with us has paddles on all four.
Levi Enstad
Sep 26, 2015 08:00 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
rgjackson
Sep 23, 2015 01:53 PM
Chasso
Sep 19, 2015 03:06 AM
