Bayou 400 - Prairie 400
Old Apr 8, 2016 | 07:52 PM
_smf_'s Avatar
Default Bayou 400 - Prairie 400
Hello , does anyone know if these models share the same topend parts?
I have a 96 bayou 400 and I think the rocker arms are bad. I'm getting loud ticking noise in topend after adjusting valves. Thanks
Old Apr 9, 2016 | 01:25 PM
Fasteratv's Avatar
Go to this site ( link ) and compare the part numbers for the two different ATV's....only way to know for sure.
Kawasaki ATV OEM Parts, CarolinaCycle
Old Apr 9, 2016 | 04:29 PM
_smf_'s Avatar
Ok thanks. The cylinders look exactly the same using all the same part numbers. They do have different part numbers for complete cylinder assembly.
It looks to me like they are interchangeable.
Old Apr 9, 2016 | 05:17 PM
Fasteratv's Avatar
If the rocker part numbers are the same....then they will change out....no problems..
Old Apr 11, 2016 | 08:42 AM
TLC's Avatar
TLC
Both use the 391cc, Liquid cooled, 4-stroke single with balancer (SOHC, 4 valves) but one is a 5 speed foot shift and the other a CVT automatic.
Here are their side by side specs 1999 Kawasaki Prairie 400 2X4 ATVs
Old May 9, 2016 | 11:21 PM
Prairie rider 1993's Avatar
Default Trying figure out my blue smoke
I got a prairie 400 I belive its 2002 it has the digital gage cluster. Things I have done is change fuel run seafoam, had run about 2 more tanks after with no seafoam, tried changing oil to see if that would make a difference nope did that 3 times on 2nd time I tries a lil bit of no smoke and that didn't help, changed spark plug nothing changed, runs fine has ***** still, smokes a lil on idle but mostly when I hammer on it, it's good but when I let off it smokes bad and I noticed engine seems to get kinda hot. I don't know if rad would cause it to smoke from getting really hot. The oil I have been using is the Kawasaki oil and fuel is mid grade ngk spark plug. Now I know it's either going to be oil ring or valve guide and seals just looking to see other recommendations before I tear it down. Quad also sat for 3 -4 years with out starting till I bought it any help would be awesome thx
MrJunk
Nov 15, 2022 01:28 AM
Chris.400
May 29, 2016 02:15 AM
schildi
1) Engine problems..
Apr 5, 2016 02:39 PM
MrJunk
Apr 2, 2016 08:54 AM
chrisarvor
Mar 31, 2016 10:39 PM
