98 sportsman 500 rear suspension issues
Old Apr 24, 2016 | 06:43 PM
alex2014's Avatar
Default 98 sportsman 500 rear suspension issues
Hi guys/
I have a 98 sportsman 500. My issue is that after I ride it the rear suspension is bottomed out. If I grab the rear rack and lift it back up everything works as it should. I have removed the sway bar links, tires and rear shocks and worked the suspension by hand while it was on a jack. The right side was smooth but the left side is binding up. I removed the top bolt that holds upper A arm to the hub and both upper and lower A arms work fine no binding. When I put that bolt back in the suspension begins to bind. If I pick up on the A arms they will hold themselves up and not fall down until I push them back down. My question is what could be going on? Could I have a bad bushing somewhere and need a bushing kit? Could it be blown shocks not pushing suspension back down? Any help would be greatly appreciated Thanks
Old Apr 25, 2016 | 09:28 AM
Original shocks? If so that can be part of it along with weakened springs over the years along with possible bushings that need replacing. I'd start at the shocks and possibly some heavy duty springs and go from there.That alone may take care of the problem.
Derikwest55
Mar 8, 2016 07:06 AM
smitty2
Where to Ride
Mar 5, 2016 10:30 PM
bvolks
Mar 1, 2016 10:15 AM
Dragginbutt
Feb 20, 2016 02:42 PM
