E-ton Viper 90R oil leaking out of spark plug hole
Old Apr 25, 2016 | 05:47 PM
Dennis0862's Avatar
Default E-ton Viper 90R oil leaking out of spark plug hole
Hopefully someone has seen this, I don't know where to start. Went to start it, turned over briefly and felt like it was hydrolocked....drained old fuel, repaced fuel filter, still the same. Removed spark plug, turned it over and the most of the oil tank emptied into the cylinder and shot out the spark plug hole...turns over freely but made a mess... could it be a pump issue or a bad engine? Any help would be appreciated
Old Apr 26, 2016 | 08:20 AM
MPDano's Avatar
I would drain your fuel tank. Block off the oil injection. Pre-mix your fuel 32:1. The fill your gas tank with it. Get all the oil out of your cylinder and replace the spark plug or clean it real good and try again.
Robert.unger
1) Engine problems..
Mar 4, 2018 02:33 AM
Timbo2500
Mar 15, 2016 10:30 AM
razman_07
Mar 13, 2016 04:06 PM
JunkQuad
Feb 19, 2016 10:59 PM
Kymco 450i
Feb 11, 2016 09:56 PM
