hard to start & irregular voltage
Old May 4, 2016 | 12:47 PM
KScott242's Avatar
Question hard to start & irregular voltage
Hello, I've got a Taotao 250cc that is acting up. The battery is having a hard time starting the bike, but it dose start if I connect a second battery ( i know the battery is good because it works fine in my 200cc atv of the same make ). Once the bike is running and I check the voltage with a multi meter, I see the volts jumping around, anywhere from 2v to 14v.
So my question is, are these two issues related, the battery doesn't appear to be charging on this atv. Could it be an issue with the stator or rectifier?
thanks in advance for your time!
Ken
Old May 5, 2016 | 09:05 AM
Zrock's Avatar
Super Quad Patrol
Could be that or the voltage regulator. Check the regulator on your other machine and see if its the same. You may be able to temporally swap em for testing.
JenniferM
Mar 17, 2024 08:21 PM
Hausner
1) Engine problems..
10
Dec 26, 2020 06:30 AM
Maxwellturner
Apr 26, 2016 06:59 AM
papa hogg scoot
Polaris Side by Sides
12
Apr 2, 2016 08:28 PM
Kazjag500
Feb 18, 2016 03:09 PM
