1999 sportsman 500 electrical issue
Old May 10, 2016 | 09:19 PM
jakelewis813's Avatar
Default 1999 sportsman 500 electrical issue
My 99 sportsman 500 is tripping the 20 amp Circuit breaker from the batter to the ignition. any idea on what or why it is shorting out?
Old May 10, 2016 | 09:39 PM
Either old and weak or sometimes they can corrode and cause it to trip. You can get these 20 amp breakers at any auto supply for a few bucks. Here's a new one compared to a bunch I've seen before. Just slice the pouch open and check it out.
Old May 11, 2016 | 07:46 AM
Hey Sir, I replaced the CB last night and it still does the same thing. the wires are warm to the touch. According to a wiring diagram that wire goes to the ignition key? I appreciate the help!
Old May 11, 2016 | 09:08 AM
The main circuit breaker allows power to the left control switch, dash along with lights and ignition switch. If a new one is still getting hot and tripping,then you have a short or faulty connection. Check connections at the battery first,then move forward through the wiring harness.
Old May 16, 2016 | 01:11 PM
Zrock's Avatar
Super Quad Patrol
One spot to check good is where the wires come up to the bars. They get alot of movement their and can rub through
bbelojr
May 14, 2016 11:21 AM
cohunter
May 13, 2016 01:49 PM
alex2014
Apr 25, 2016 09:28 AM
Fubar008
Apr 19, 2016 09:18 PM
shane019
Apr 13, 2016 04:46 PM
