2011 Sportsman 90
Old Apr 13, 2016 | 03:35 PM
shane019's Avatar
Default 2011 Sportsman 90
Hi Guys,
I have a 2011 Sportsman 90 that doesn't want to run properly.
It will idle playing with the choke but soon as you give it throttle it starts to spit and sputter and eventually stall. It will barely move.
I have had the carb off and cleaned probably 10 times with it only getting slightly better.
- Changed Spark Plug
- Change Fuel Filter
- took apart and cleaned shut off valve
- Cleaned air filter
I am wonder if it could be a weak spark issue or maybe valves out?
Anyone have the Valve spec?
CDI, Coil or Stator?
Any other thoughts?
It seems like fuel issue but I have done everything I could think of and it hasn't made a difference. All jets are clean, float and needle and seat move freely. I thought I was a needle and seat issue but everything looks fine. Any chance it could be the needle and seat? its over $60 for new needle seat and float.
Thanks, Shane
Old Apr 13, 2016 | 04:46 PM
Rather than guess at problems a cheap 5 buck service manual with maintenance specs, trouble shooting guides along with electrical tests can help you narrow down the problem.2011 Polaris Sportsman 90 Service Manual PDF Download
Robert.unger
1) Engine problems..
Mar 4, 2018 02:33 AM
MapleNeil
Feb 15, 2016 05:22 PM
Joe04785
Jan 25, 2016 12:12 AM
Timbo2500
Jan 24, 2016 11:17 AM
TaoTao110D
Jan 21, 2016 01:23 AM
