Buying an ATV Questions and suggestions about what to buy, financing, insurance, etc.
Check out my crack...
Old May 12, 2016 | 12:03 AM
toonces's Avatar
Default Check out my crack...
What's the best way to fix this?...
Best idea so far is to clean it all up, sand the bottom side real good and find a piece of durable plastic I can shape and form to the bottom, and sand it as well. Then hold it all together somehow and epoxy the formed plastic to the bottom side. After curing, drill holes on both sides of the crack and thread wire through like shoelaces for support, pull tight and tie off.
Seems like I read about some kind of goop you could use in this situation but I forget what it was called. I believe it would take the place of the epoxy.
Right now I need advice on what kind of plastic to use and how to source it, as well as what kind of epoxy.
I'm all ears.
Old May 12, 2016 | 08:32 AM
hydrex's Avatar
Why not try the liquid plastic repair stuff that cures with the UV light?
Old May 12, 2016 | 11:10 AM
greg74's Avatar
My Grizzly had a tear in the right front fender like this. I just drilled a few holes in the plastic and put some big zip ties in it I already had to keep it from tearing more. It wasn't the prettiest repair job but it was a 10 year old quad so I didn't care if it looked perfect. It seemed to hold up. I wonder if that Gorilla glue stuff I see advertised on tv bonds to plastic. There was another one where they glued a chain together and pulled a truck with it or something. I'm sure the results were exaggerated but I guess they proved a point.
Old May 15, 2016 | 01:34 PM
toonces's Avatar
Thanks for the good advice yall. This is a 2011 700 Grizz and someone pointed out the pieces for the newer models are backward compatible and much cheaper like around 25. For this price I'll just go ahead and replace.
Old May 15, 2016 | 01:44 PM
user493's Avatar
Moto Psycho
I had a quad that I broke the plastic on the foot well area on and I pop riveted a piece of galvanized pipe strap on both sides of the crack. It looked like a Frankenstein repair job but it worked and lasted for as long as I had the quad. Sioux Chief 3/4in x 10ft Galvanized Hanger Strap (524-1022PK2) - Pipe Hangers & Straps - Ace Hardware
Old May 16, 2016 | 07:21 AM
toonces's Avatar
Yeah that hanger straps good stuff. All around great fixit material
RedRancher
Jan 12, 2026 04:06 PM
christhorsson
1) Engine problems..
Aug 7, 2016 03:35 PM
4-tracker
Where to Ride
May 11, 2016 09:38 AM
Zephead98
May 9, 2016 10:17 AM
TerraproScotty
May 2, 2016 06:23 PM
