What is behind this cover?
Old May 13, 2016 | 02:01 PM
Visionist's Avatar
Default What is behind this cover?
There seems to be a small amount of oil leaking from the bottom of this cover and Im wondering whats behind it. On of the screws on the bottom of it stripped the threads inside upon removal so its likely not sealed fully in that spot. I will likely just use some seal all to stop it leaking but would like to know what I'm sealing off. It could also be the gasket is rotted but I really don't want to remove the other screws risking the threads being stripped on those as well.
Bike is a big bear 350
Old May 14, 2016 | 06:03 PM
Visionist's Avatar
Okay so its the "middle gear". Can this black cover be removed without removing the whole assembly(swingarm, rear diff etc)? I may just need to retap the threads and replace the gasket.
Old May 16, 2016 | 12:31 AM
Visionist's Avatar
Thanks for all the help folks.....
Screw wasn't stripped, had the two screws mixed up and apparently one is longer. I still applied some seal all to the area that was leaking and that seems to have done the job for the moment.
Old May 16, 2016 | 12:14 PM
Fasteratv's Avatar
LOL. I'm thinking that many of didn't know the awnswer to your question.... I have worked on ATV's for many years ( others here as well ) and I have never been in that area of a Yammie....
Hollywoodbadguy
Jun 2, 2016 05:25 PM
kencbs
May 18, 2016 08:29 AM
Hollywoodbadguy
Technical and How-To Articles
May 2, 2016 02:46 PM
Roellis
May 1, 2016 10:10 PM
DennisZ
May 1, 2016 02:48 AM
