need help with Raptor 660r
I just got a Raptor 660r. It was running the kid said and he traded it for an the guy he traded it to said he rode for like 5 mins and it stopped running. So Now i have it. It turns over but sounds like it isn't getting any fire what so ever. I changed the spark plug and checked to see if it was getting spark and it was getting spark. I even went and sprayed some starting fluid in each carb and it did nothing. sounded no different. I was thinking maybe the timing chain or belt not sure which is on this quad. But if anyone else has had this issue and could shine some light that would be great thanks. Also is there a easy way to check the timing chain or belt without having to take a bunch of things off?
If you could get with me asap that would be great thanks best to just text me on my cell at 937-477-2152 thanks. I am also looking for a pc5 for my 07 raptor 700r thanks and dual exhaust
I checked the chain and it's turning and on. I see it spitting fuel but I know I took starter fluid and sprayed so.e in each carb. And it changed nothing on how it sounded as it was turning over. Does it mean that maybe a jet is clogged not sure. Thinking on doing a carb rebuild on it and see what's going on. How do I check the compression on the engine?
Look up some you tube videos....lots of good "how to's" on there.
NJ4LIFE23
Mar 1, 2016 01:57 PM
