Bottom End Removal
Old Jun 4, 2016 | 05:41 PM
Timbo2500's Avatar
Default Bottom End Removal
I am trying to swap bottom ends on a 2008 250 Big Bear. Per the attached picture can anyone confirm if I have to unscrew the large nuts on #4 to remove the bottom end? Thanks, I just wasn't sure if this secured the engine at the
u-joint and I didn't want to unscrew if it's not necessary. Thanks
Old Jun 6, 2016 | 12:13 PM
DirtDevil101's Avatar
What exactly do you consider the "bottom end"? #4 are the swing-arm nuts per the manual...
Old Jun 8, 2016 | 03:50 AM
Looks like Yamaha think you need to remove the swinging arm to get the prop shaft out of the transfer box. You can get most engines forwards far enough to get the shaft out without doing this, but the writers of the book should know what they are on about.
79f250guy
Jun 17, 2016 12:34 PM
96superflow
10
Jun 9, 2016 05:13 PM
hondamxerd
Utility ATVs
Jun 4, 2016 11:24 AM
Thalowin
May 14, 2016 09:14 AM
