Engine Noise...
Not sure what happened with the previous post, so we will try this again...
I have an engine noise that has developed and gotten worse since I have owned the ATV. It is a 2001 Polaris 500 Sportsman 4x4. I have had to do a lot of up keep on it. From replacing axles, fixing reverse indicator switch, bleeding the cooling system of air, rebuilt the carburetor, and replaced the starter. There is much more I have done, but this is the bases of it.
The ATV sat for awhile waiting for me to install the starter, when I finally did I did not remember the noise from the ATV previously. I am not sure if it is in the top end as in it needs the valves adjusted or if it has something to do with the Bendix/starting assembly or the recoil starter. I would like to isolate the problem before I put anymore time into it trying to diagnose the problem. Below is a video of the noise. I did not replace the Bendix when I replaced the starter, which tends to draw me to that conclusion. I still need to dial the carb in as far as tuning goes but it runs like a scalded dog otherwise. The noise just gets worse with more RPM's.
Any help or assistance you can give on where to start would be greatly appreciated! Thanks.
Running previously, only thing changed is the starter between videos.
