Sportsman 500 Noise
Old Jun 28, 2016 | 10:20 AM
Freddyh123's Avatar
Default Sportsman 500 Noise
Hello, I have been having a problem with my 2000 sportsman 500. Has 2400 miles on it (all stock). Was riding it around a little after it sat for a few weeks, pulled it back in my garage and put it in neutral when a small grinding/whirring sound came from the bottom of the engine. Took off the belt cover and everything is fine in there. Don't think it is anything major (crank, cam, etc) since it still starts right up and runs fine, can even ride it around with no loss in power at all, but don't want to rule anything out. Checked all the fluids and they are all good. Here is a link to a video with the noise-
Skip to 2:25 to hear the noise (first problem in the video has already been fixed)
Thanks in advance
Old Jun 28, 2016 | 11:31 AM
DON'T disconnect a battery from a running engine,especially on these later models as you can do damage to the cdi,that new regulator,etc. The grinding noise is more than likely the drive clutch hitting the clutch cover.You can move the small "L" bracket behind the inner cover a little forward and see if it helps. If not the clutch cover has been updated in the parts breakdown. Item#27 is the bracket. Dirt Cheap Yamaha, Polaris, Suzuki & Kawasaki OEM Parts & Accessories – Cycle Parts Warehouse
Old Jun 28, 2016 | 12:02 PM
Freddyh123's Avatar
ok thanks, I will try to adjust that and see if it helps, thanks for your input.
Old Jun 28, 2016 | 02:43 PM
user493's Avatar
Moto Psycho
It doesn't have anything to do with the grinding sound but you should replace the winch solenoid if it's bad instead of just bypassing it.
superunknown23
Feb 23, 2016 12:39 PM
Feb 17, 2016 06:02 AM
F5guy
Feb 1, 2016 04:54 PM
ATVAdventurer
Where to Ride
Jan 10, 2016 02:00 PM
Peeps
Mar 24, 2000 12:27 AM
