Need some advice!!
Old Aug 3, 2016 | 06:23 PM
TreeSlayer91's Avatar
Default Need some advice!!
I have a 2011 Grizzly 700 EPS 4x4.... Battery is not charging, just replaced the stator, regulator rectifier and battery... Went for a few rides and now the battery is dead again... What else could it be? Thank you
Old Aug 4, 2016 | 01:35 AM
The wires between the battery and regulator. They can get a high resistance due to a partially broken wire or bad earth and the regulator will not charge if it doesn't get a signal of true battery voltage. Could also be a dud new component. You should have checked what the voltage across the battery was with the engine running, before and after changing each component, should be between 13v and 14.5v. Can also be a drain due to a fault somewhere else on the bike. Disconnect a battery terminal and check with an ammeter between the battery terminal and the wire going to it. With ignition off, it should be milliamps.
TheATVSuperStore.com
TheATVSuperStore
Nov 21, 2016 08:56 PM
Boxertim
Oct 30, 2016 10:18 PM
Kord02
Oct 10, 2016 01:04 PM
Zephead98
Jul 22, 2016 04:27 PM
J wolfe
Jul 16, 2016 09:23 PM
