New to my wife '05 Rancher 400
Old Aug 11, 2016 | 09:52 PM
ram1000's Avatar
Default New to my wife '05 Rancher 400
Just brought home this 400 in good condition but needs tires. It has the elec/auto transmission and I want to use 25" tires where it currently uses 24" tires. I would have to replace the rear rim as it is an 11" rim and I would use 12" rims all around. The front is already a 12" rim. My question is can I swap out the taller tire (25" vrs 24")without serious repercussions? Looks like about 5% difference
Old Aug 12, 2016 | 02:46 AM
You can fit 25 outside dia tyres with no problems, but why are you changing to 12" rims?
Old Aug 12, 2016 | 08:47 AM
ram1000's Avatar
Changing to 12" rims because I bought a CanAm and want to use the OEM tires off the CanAm on her ATV and buy more aggressive tires for my 570
Old Aug 16, 2016 | 10:13 AM
TLC's Avatar
TLC
Go for it. I put rear 26x11 and front 26"x9 Zilla's on a Mid chassis Yamaha 350 Bruin with out coming close to anything rubbing.
I always thought it was odd that Honda put little 24" on the ranchers. Cost saving I would guess.
Is two new rims cheaper then buying two 25x10-11 tires?
Old Aug 16, 2016 | 10:54 AM
greg74's Avatar
As long as you keep the same size tires all the way around, going to 25" tires is no problem. Honda puts 24" tires on the new Pioneer 500 side by side. Most people change those out pretty soon after they get it. Its geared so low that it actually improves performance by going with a bigger tire. As far as using 12" rims, I'm sure you can find some older Foreman wheels which I think should fit and you'd have your 12" wheels.
Old Aug 16, 2016 | 10:57 AM
TLC's Avatar
TLC
Make sure the off set of the rim is the same. Here is a good rim chart to look up off set and bolt pattern. ATV Tire and Wheel Application Chart : ATV Tires Free Shipping : ATV Wheels : Mud-Throwers.com
konstan
Mar 4, 2019 07:06 PM
mtnxtreme
Aug 11, 2016 11:53 AM
Strickland84
Aug 10, 2016 03:30 PM
bodatiouskid
Aug 9, 2016 01:36 AM
toonces
Jul 19, 2016 07:18 PM
