ETON Yukon II backfires to exhaust and stops when changing gear
Old Sep 6, 2016 | 02:00 PM
darkyputz's Avatar
Question ETON Yukon II backfires to exhaust and stops when changing gear
Hello and first of all...great forum...thx for this great place
Was jut reading in the past, but now i have my own issue...smile
Got a Yukon II for free and changed oil, gas, spark plug and cleaned carb...
Started up just fine (besides that i had to jump it)
BUT...it smokes like hell in white and backfires into exhaust...
Also, as soon i try to change the forward/backward lever, it stalls right away...
Does that sound familiar to anyone?!
Haven't done Compression test because the plug is so small that i have to get an adopter first...
Hope anyone can help...
Thx in advance
Old Sep 7, 2016 | 09:20 AM
Zrock's Avatar
Super Quad Patrol
sounds like the carb may need to be adjusted or cleaned and adjusted again
Old Sep 7, 2016 | 11:57 AM
darkyputz's Avatar
Hello and thx for your reply...
Do you think white smoke can be cause d by that?!
But i will check...
Just cleaned it, so now will play with adjusting...thx...
Seafoam any help? What do you think?!
Old Sep 8, 2016 | 01:47 AM
White smoke is often a sign of water in the system, some water from the fuel tank may have got into the carb. You will see it in the float bowl when you are cleaning, if this is the problem. It may be that the engine is running so badly that the smoke is un-burnt fuel.
Old Sep 8, 2016 | 07:57 AM
darkyputz's Avatar
The carb was bad dirty...so i ultra sonic'ed it and cleaned all vents and holes with pressure air...looks like new now and starts up just nice...but still horrible run...
And still...waiting on adapter for my compression tester...
Do you have a atv like that?!
Timbo2500
Mar 26, 2016 09:41 PM
smitty2
Where to Ride
Mar 5, 2016 10:30 PM
Blodg500RX
Oct 17, 2002 01:33 AM
SandDraggin
Jul 31, 2000 09:47 PM
richy26
Apr 5, 2000 08:28 PM
