starter
Old Sep 19, 2016 | 08:28 AM
cubano222's Avatar
Default starter
Can someone tell me how to remove the starter on my Hi Bird 250cc? I removed 3 bolts on one side & when I removed that, there was a gear in that cover. I removed the long screws on the other side but the starter didn't budge, plus the exhaust is in the way. It is a top mounted starter & it appears that is it dragging causing the battery wires to get super hot when cracking. Cranks a lot faster with the spark plug out & wires don't get hot but with the plug in, starter drags & wires get hot only when cranking. I have researched the internet but can't find anything showing my specific starter removal.
Old Sep 21, 2016 | 10:10 AM
hugemoth's Avatar
Assuming it's the CG type engine all that is holding the starter is the 2 bolts behind the exhaust pipe. Maybe the O ring has hardened and will take some persuasion.
Old Sep 21, 2016 | 12:31 PM
cubano222's Avatar
Are you saying the long screws that are phillips head or the 2 bolts that are bolted on the engine case? If it's those 2 bolts, looks like I'll have to remove the exhaust to get to them.
Old Sep 21, 2016 | 02:15 PM
hugemoth's Avatar
It's the two bolts that screw into the engine case.
Old Sep 21, 2016 | 02:49 PM
cubano222's Avatar
I didn't try those 2 bolts cause it looked hard to get to. If I remove those bolt, will the starter just come off? Is there a chain involved or does the starter have a gear that turns the motor over. I want to make sure I don't screw something up. Thank you
Old Sep 21, 2016 | 03:24 PM
hugemoth's Avatar
Remove those bolts and the starter will pull out. No chain. The reduction gears will stay in place.
Old Sep 21, 2016 | 03:29 PM
cubano222's Avatar
Thank you so much for your help. I feel like I can do it now. Then I can see what type of starter I need to order.
Old Oct 5, 2016 | 11:11 AM
cubano222's Avatar
Got the starter off after removing the exhaust. Came off pretty easy. It is a 9 spline & will order a new one from VMC Chinese parts for $22.50
WilliamBos
Sep 9, 2016 08:06 PM
DustinC
Sep 6, 2016 05:39 AM
buffadonk
Sep 5, 2016 07:03 AM
jasarc
Aug 30, 2016 12:27 PM
