Recon 250 Loses Power
Old Sep 22, 2016 | 01:30 PM
Zephead98's Avatar
Default Recon 250 Loses Power
My son was out riding last night, and when he came back I could tell something was wrong. It struggled to go up hills, and would occasionally stall struggling up a hill. Anything beyond 3rd gear is pretty useless, if you press the throttle it will struggle, then bog and almost stall. I found a hose disconnected sort of under the air filater box, the spring clamp had come undone and the hose had slipped off. I reattached the hose and clamp thinking had fixed an easy one , but other much change. Smells rich too when idling
Any hints to where I could look?
Old Sep 23, 2016 | 01:55 AM
The choke mechanism may be sticking so check it. Also check that the air filter is OK. If they are not the problem, treat it to a new plug and check if the old one is black and sooty. If that doesn't cure it, clean the carb out. Remove and clean the jets and float needle, and blow compressed air through them and the orifices.
Old Sep 23, 2016 | 07:59 AM
Zephead98's Avatar
Yeah I thought the same thing about the choke, but I think it is OK. If I pull the choke out, it automatically stalls. SO I think that is good.
Was thinking the spark plug too, was going to buy one now, but apparently there are about 30 diff kinds, so I need to get the old one out and get the part # off of it.
Old Sep 23, 2016 | 06:44 PM
Zephead98's Avatar
Sheesh, that spark plug was a joy to remove. Looked like it came over on the Mayflower.
New spark plug, no change.
Sprayed the carb and choke with carb cleaner, and bingo...all better.
Thanks merryman for the help!
Myridge
Sep 19, 2016 12:56 PM
Grizzly 550 esp go 2012
ATV Expeditions
Sep 19, 2016 12:32 AM
cschahl98
Sep 15, 2016 01:40 AM
drm50
Aug 29, 2016 02:45 AM
