ds 650 wont star only backfier
Old Sep 25, 2016 | 02:21 PM
Deiti's Avatar
Default ds 650 wont star only backfier
I have a ds 650 model year 2004, and it just backfire
it compresses normal and gets normal petrol, but when I tried to fire it up its
like something striking together
Old Nov 18, 2016 | 07:17 AM
MRDS650's Avatar
Canadian and Proud of it !!!
I am betting you have sheared off the crankshaft keyway - it's a common problem in these bikes - I have had it happen a couple of times. When it does happen the timing goes out causing the engine to backfire. You need to get the engine to TDC and lock it- insert a special bolt under the gearshifter in the crank. Then remove the side cover by the brake pedal, Pay attention how everything comes apart, it needs to go back together a certain way. Then remove the flywheel, you will need a special tool to do this. They can be bought off ebay. Inspect the crank, I am betting that the timing has jumped when the key broke.
Old Feb 4, 2017 | 12:51 PM
MPDano's Avatar
Yup. Agreed. Pretty common on a lot of different make ATV's. Timing is off, thus backfiring.
dalebergman@wildblue.net
Oct 4, 2016 06:57 PM
Mark1979
Sep 28, 2016 02:38 AM
brinkkl2000
Sep 26, 2016 12:01 PM
Outdoordave
Yamaha Side by Sides
Sep 25, 2016 07:53 PM
Lynnard
1) Engine problems..
8
Sep 23, 2016 09:23 AM
