Baja Motorsport Idling Super High
Old Sep 26, 2016 | 08:43 PM
rdhj's Avatar
Default Baja Motorsport Idling Super High
my sons bike died one day and wouldn't start...thought it was was flooded and checked the float height..it was fine...cleaned it all out and didn't help...it will start with the choke on, allow me to put it the closed choked if it is warm enough. however it revs so high that the quad wants to take off...adjusting the idle screw or fuel screw does not help...spark plug was black and dry on the top but wet on the bottom and stunk like gas...cant find any air leaks....anyone have any ideas what else to check
Old Sep 27, 2016 | 06:42 AM
LT80's Avatar
LT80 Expert
Sounds like it could be a crank seal.
I'd check the compression tho.
Old Sep 27, 2016 | 08:23 PM
rdhj's Avatar
how would a crank seal cause a vacuum leak?
Old Sep 28, 2016 | 07:13 AM
LT80's Avatar
LT80 Expert
Ooops...I am presuming you have a 2 stroke motor.
If so, a seal leak sucks air in leaning it out thus a higher uncontrolable idle.
The sustained choke to stay running points toward the seal and/or compression.
Old Oct 1, 2016 | 10:13 AM
MPDano's Avatar
Does sound like a vac leak tho. Make sure you put the carb to head intake on correctly. Easy to put on incorrect.
Old Oct 2, 2016 | 09:14 AM
Zrock's Avatar
Super Quad Patrol
Check your throttle cable as well.. Sometimes they get moved and it will cause the cable to tighten up and lift the slide increasing the idle and making it hard to start.
Aug 4, 2016 03:39 PM
papa hogg scoot
Yamaha Side by Sides
Jul 28, 2016 07:00 PM
bradleyheathhays
Jul 24, 2016 03:55 PM
Jul 20, 2016 06:12 PM
cornermike
Jul 1, 2016 02:55 PM
