tire stretch
Old Oct 2, 2016 | 11:15 PM
wamulass's Avatar
Default tire stretch
I found a nice pair of DWT 14x11 wheels for only $100. The problem is I can't find a tire wider than 12 inches without being a paddle tire.
So anyone ever tried stretching a tire on the wheel? I know people do it on low riders and cars with low profile tires. I currently have 26x11-14 tires. They measure about 10 inches wide when aired up.
Old Oct 4, 2016 | 09:24 AM
Kymco 450i's Avatar
On the diameter you need to be the correct size but on width there is a lot of variation to be had. I have seen lots of tires mounted that were to wide and to narrow. They will mount but tire wear may be an issue. If the width gets to far off then premature tire wear is to be expected.
Old Mar 6, 2017 | 02:00 PM
2004pred's Avatar
I dont think tire wear will be your biggest issue. (Unless you are going on the road) Keeping the tire on will be. The wider the rim the harder it is to keep the bead on.
res2fr
1) Engine problems..
Nov 23, 2016 01:38 PM
Dixieboy515
Oct 9, 2016 10:21 AM
LB Kearce
Sep 29, 2016 08:23 PM
jtague80
Sep 27, 2016 05:27 PM
jtague80
Sep 27, 2016 05:10 PM
