Blackwater XT Tire- Traxter 2000
Old Apr 15, 2001 | 11:43 AM
teitu's Avatar
I ' ve got the blackwater XT (27 ') set for my traxter 2000, but when I dress the ATV with the
set, the quad shake going forward but not in reverse. The manufacture advertise the XT 27x9x12
and 27x12x12 to fit the traxter. Question: do I need any extra modification in order to use this
set? Which could be the reason for the shake ? Thank for your help. teitu
Old Apr 16, 2001 | 12:51 PM
fishbones's Avatar
You may need to balance the tire on the rim just like you would on a car tire, or you may have some mud dried to the inside wheel well. It will shake more at higher speeds. Make sure you put them on the ATV correctly. Use the star method when securing the wheel to the axel. Hope this helps.
Old Apr 17, 2001 | 12:37 AM
BONER's Avatar
If you are talking about at extremely slow speeds I am betting it's the extra lug spaceing that is makeing your ATV Shake as each lug hits the hard surface.
Old Apr 17, 2001 | 10:06 AM
teitu's Avatar
Yes ,I'm talking at extremely slow speeds.I did
not intent at normal speed.
Old Apr 17, 2001 | 10:16 AM
teitu's Avatar
Can you tell me,wath is the star method when securing the wheel to the axel? Thank you for your
help.Teitu
Old Apr 17, 2001 | 10:48 AM
kindsambo's Avatar
I would say you bought the wrong tire for your driving style. If you're running on alot of hard surface you're going to get a rough ride...should lessen at higher speeds. I drive on alot of hard packed roads myself so I bought a tire that was well suited for all types of driving...hence my dirt devels. But you have an awesome tire if you do plenty of mud running.
Just my two cents.
Old Apr 17, 2001 | 11:03 AM
kindsambo's Avatar
How much air pressure do you have in your tires? Try going with 3lbs...less air will help the ride a bit but will also make your steering heavier. Tis the price we have to pay for a good 6 ply mud tire.
Old Apr 17, 2001 | 11:04 AM
teitu's Avatar
Dear Friend
I really apreciate your input and your sense of humour. Thanks
Teitu
Old Apr 17, 2001 | 06:09 PM
teitu's Avatar
Yes,I was looking for the 6 ply,too many thorn, I try with to much pressure(8Lbs),gona try with 4 lbs.Thank again
Old Apr 21, 2001 | 09:39 AM
MJSTX's Avatar
I have the same setup as you have (2000 Traxter with Blackwater XT'S)and I run them with 4.5 psi in he back and 5 psi in the front. At very slow speeds, there is some vibration on the handle bars but this goes away above 5mph. These tires are vast improvement over the original tires. They are great for normal trail riding, muding and in the snow. I have 3000km on my Traxter with no significant problems so far.
MeadowlarkFarm
Nov 27, 2019 08:40 PM
Gwolf228
Feb 18, 2017 01:36 AM
Dammar
Apr 20, 2016 06:03 AM
Scooter's Shop
Oct 9, 2015 02:09 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
