OIL LEAK
Old Apr 15, 2001 | 09:18 PM
SPORTSMAN005's Avatar
WENT OUT RIDING LAST NIGHT , WHEN WE GOT BACK IN MY FRIENDS '99 A/C 400 4X4 WAS POURING OIL OUT FROM UNDER THE BOTTOM OF THE CRANKCASE. HAVE ANY OF YOU HAD A SIMILAR PROLBEM?
IT'S NOT COMING OUT OR AROUND THE DRAIN PLUG, LOOKS LIKE IT'S AROUND ONE OF THE BOLT IN THE CRANKCASE..
GONNA TRY TO CHECK IT OUT WHEN HE BRINGS IT BACK WENESDAY OR THURSDAY.
ANY HELP WOULD BE APPRICATED
THANKS,
SPORTSMAN 005
Old Apr 16, 2001 | 12:29 AM
dakotart's Avatar
Without seeing it I would have no clue but some guys have had leaks around the rear main seal on the output shaft. But I don't think they said anything about "pouring out" either so we may be looking a totally different problem. Good luck with it.
Dakota R/T
Old Apr 16, 2001 | 01:12 PM
nailbender's Avatar
Check the lower rear corner of the side cover gasket (left side sitting on the machine) I'm on my third gasket now. My dealer said there is a gear or a shaft that puts pressure on the side cover and stretches the bolts. The last gasket he put in was made of a heavier material and it seems to be holding up so far.
I know of a couple other people that had the same problem,all of us have big tires and do alot of hard riding which could be the cause of the problem.
Old Apr 16, 2001 | 06:13 PM
THAT'S IT !!!!!
IT'S LEAKING AROUND THAT SAME SPOT. THE LOWER LEFT SIDE OF THE CASE TOWARD THE REAR.
HOW HARD IS IT TO FIX? WILL I HAVE TO PULL THE MOTOR OR IS THERE A QUICK FIX? IF I PULL THE MOTOR WILL I SPLIT THE ENTIRE CASE OR CAN IT BE SPLIT JUST ENOUGH TO USE A TPYE OF FORM-A-GASKET.
THANKS,
SPORTSMAN 005
Old Apr 17, 2001 | 08:24 PM
nailbender's Avatar
I had my dealer do mine but he did explain it to me. You won't have to pull the motor,just take off the side cover.
I wouldn't use "form-a-gasket" myself,just make sure you get the newer heavier style gasket from Cat.My dealer also used some type of gasket glue to hold it together better,make sure both sides are clean and dry.
One tip I have,would be to get the motor warm and retorque the bolts several times after you get it back together
Old Apr 18, 2001 | 12:30 AM
aczr2k's Avatar
The leak on the lower left side of the case, I think the update is a new cover, and different bolts, maybe a just a strap between the bolts, not exactly sure, I will ask around. Aczr2k
exmotocrosser
Sep 13, 2019 06:12 AM
1ArmBandit
55
Oct 14, 2015 09:03 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
wrencher82
Sep 24, 2015 03:39 PM
bvolks
Sep 13, 2015 12:57 PM
