2) Chassis problems.. If your quad runs but you have other problems.. post in here.
Kazuma meerkat 50cc
Old Jan 26, 2017 | 03:17 PM
Wezza's Avatar
Default Kazuma meerkat 50cc
So I just brought my kids a Kazuma meerkat everything seems ok I've replaced seals carb air box system lights spark plug oil etc I'm having a problem with the steering ... When turning the quad isn't very responsive at all can someone please help me thanks
Old Jan 26, 2017 | 03:25 PM
DirtDevil101's Avatar
Can you explain the symptom a bit better? Not responsive when not moving or just turns lazy when rolling?
thx
Old Jan 26, 2017 | 03:31 PM
Wezza's Avatar
Default Kazuma
thx
seems fine when standing still but while driving it just wants to go in a straight line hope this helps
Old Jan 27, 2017 | 03:47 AM
Toe in/toe out is the obvious one, but a previous owner may have fitted wheel spacers or non standard front wheels. Check the toe in etc, and remove any spacers between front wheels and hubs.
Old Jan 27, 2017 | 07:48 AM
UnkleRaRa's Avatar
Maybe there is a blown steering stem bearing, and when you put weight on the handlebars, it drops the stem down.
Is there any up and down movement of the handle bars if you stand on the machine and pull up?
Old Jan 27, 2017 | 08:45 AM
Is that with you riding it? sometimes when there is too much weight to the rear the machine will try to track straight even though the handlebar is turned...basically an overly light steering condition...
Wezza
Jan 26, 2017 03:14 PM
