425 Xpedition clutch adjustment
I just had to replace the gear shift selector rod on my Xpedition, and after I buttoned it up, the machine will not move, although I can feel and hear it go into gear. It feels like a clutch is slipping. anyone have any experience on adjusting the clutch, and how I would go about doing it?
Thank you
Mark
Thank you
Mark
1. Turn engine off.
2. Remove protective cover to access adjuster screw.
3. Loosen lock nut.
4. Turn adjuster screw out (counter clockwise) until resistance is felt.
5. Turn the screw in (clockwise) 1/8 -1/4 turn.
6. Hold the adjuster screw in position and tighten lock nut securely.
7. Replace protective cover.
3. Loosen lock nut.
Njrider1230
Jul 29, 2023 05:16 AM
2000, 2001, 425, adjust, adjusting, adjustment, clutch, expedition, expendtion, expidition, explain, grabing, polaris, recall, xpedition
