2004 yamaha warrior 350
Old Apr 20, 2017 | 08:19 PM
sunnyjohnson's Avatar
Default 2004 yamaha warrior 350
keeps turning but wont fire... replaced battery, relay, spark plug, fresh gas, oil good,checked connections...I need help please.... lol oh and Im a girl and learning still on my fourwheeler lol
Thank you
Corliss
Old Apr 21, 2017 | 10:37 AM
rider77's Avatar
What's the carburetor look like? Was it stored with gas in it?
Old Apr 21, 2017 | 09:05 PM
slimmer455's Avatar
Will it fire with starting fluid? If not it could be a coil.
Old Apr 23, 2017 | 04:16 AM
First find out if you are getting a spark by removing the plug re-connect the HT lead and lay the plug on the head. Press the starter and see if the plug is sparking. If it is, check compression if you can. If this is OK (over 90psi) go for the starting fluid, though I have known this not to work. If it isn't sparking, either get a workshop manual and go through the ignition circuit checks, or get a motorcycle/quad auto electrician to check it over. Don't just fit new parts, you could spend a lot of money, still not have a "runner" and then find it was a broken wire.
Old May 16, 2017 | 06:14 PM
YamahaMoto's Avatar
Country Rider
First, I think its cool for a girl to do motocross. Its good to show that its not just a guys sport. Second, by checking the connection, what connections did you check. I had a fairly similar problem on my quad and I found out that one of the valves on the top of the carburetor was having an air leak. All I had to do was take it off, and screw it back on better and tighter. If you want any more info, questions, or anything else, you can private message me.
atvgirl6109
Jan 3, 2017 11:00 PM
bernhardschmidt
Oct 31, 2016 12:28 PM
LB Kearce
Sep 29, 2016 08:23 PM
Raphael Lechasseur Coté
Sep 25, 2016 03:14 PM
atom0s
Jul 21, 2016 11:44 AM
